Straight whip antenna vs fiberglass antenna
SW-UHF390 Straight Whip Antenna: Key Features
Frequency Range : The operating frequency range spans from 400-470 MHz, meeting the communication requirements within the UHF frequency band.
SWR Performance : At 433 MHz, the voltage standing wave ratio (VSWR) is ≤ 5, and within the 400-470 MHz band, the SWR is excellent (≤ 8), effectively ensuring signal transmission efficiency, reducing reflection losses, and improving communication quality.
0 dBi Gain : The SW-UHF390 provides 0 dBi of gain, making it suitable for wireless communication applications that require stable signal strength.
Durability : The antenna offers excellent vibration resistance and anti-aging capabilities, ensuring stable performance in harsh environments over extended periods.
Easy Installation : The straight whip design makes the SW-UHF390 antenna very easy to install, with an SMA-J interface that is compatible with a wide range of devices.
Maximum Power : The antenna supports a maximum input power of 10W, making it suitable for use with medium-to-low-power wireless devices.
BLG-UHF40 Glass Fiber Antenna: Key Features
BLG-UHF40 is a glass fiber antenna customized for wireless communication in the 410-490 MHz range. The antenna offers excellent SWR performance, easy installation, stable performance, and is highly resistant to vibration and aging
BLG-UHF40 fiberglass antenna has the following main features:
Frequency Range : The operating frequency range is 410-490 MHz, making it adaptable to various wireless communication environments across different regions and frequencies.
SWR Performance : The antenna has an excellent voltage standing wave ratio (VSWR) of ≤ 1, providing extremely low signal reflection, ensuring efficient signal transmission.
3 dBi Gain : The BLG-UHF40 provides a 3 dBi gain, making it ideal for applications requiring wider signal coverage and stronger reception, especially in long-distance transmission scenarios.
Omni-Directional Radiation : The BLG-UHF40 features omni-directional radiation, enabling 360° signal coverage, ensuring uniform distribution and stability of the signal.
High Power Support : This antenna supports a maximum input power of 100W, making it suitable for high-power wireless devices or large-area signal coverage applications.
Durability : Made from fiberglass, the antenna exhibits excellent vibration resistance and anti-aging capabilities, making it suitable for long-term use in harsh environments.
Easy Installation : The BLG-UHF40 uses an N-type (male) straight plug interface, making it easy to install and compatible with a wide range of wireless communication devices.
