Dear,
I have tried to re-flash the board D-duino-32 SD but always when I run “esptool.py” it go out with a fatal error
For example if I execute:
The tool do:
[code]esptool.py v2.5.1
Found 1 serial ports
Serial port /dev/ttyUSB0
Connecting…………………_____
/dev/ttyUSB0 failed to connect: Failed to connect to Espressif device: Timed out waiting for packet header
A fatal error occurred: All of the 1 available serial ports could not connect to a Espressif device.
[/code]
The board do RESET but never enter in DOWNLOAD mode, always in BOOT mode
From PuTTY:
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0008,len:8
load:0x3fff0010,len:2232
load:0x40078000,len:11744
load:0x40080000,len:252
entry 0x40080034
E (251) sdmmc_req: handle_idle_state_events unhandled: 00000004 00000000
E (252) sdmmc_cmd: sdmmc_card_init: send_op_cond (1) returned 0x107
Card Mount Failed
Where is the problem?
Is the schematic available?
Thank you
Dino
