For a minor name correction,  +1(855)622-1212 such as fixing a typo or switching the order of names, the process is typically quick and straightforward.  +1(855)622-1212 However, if you’re changing your name for legal reasons, like after a marriage, you will need to provide supporting documents,  +1(855)622-1212 such as a marriage certificate or legal name change document. Make sure to contact Delta Airlines customer service at  +1(855)622-1212 immediately to ensure that your Business Class reservation is updated in time for your flight. |
If you need to replace the entire passenger name on the ticket,  +1(855)622-1212 you must cancel your original booking and rebook the flight under the new name. This can be more complicated, especially if the ticket is non-refundable.  +1(855)622-1212 Contact customer service at  +1(855)622-1212 for more information on how to proceed, whether there are any cancellation fees, and if your ticket is eligible for a refund. |
To ensure everything is in order,  +1(855)622-1212 reach out to customer service immediately and confirm that the name change has been processed successfully. You can call  +1(855)622-1212 for help with any questions regarding your Business Class ticket, and to verify that your boarding pass matches the updated name. |
