UWB base stations have the following installation requirements?
Each UWB base station should be at least 30 cm away from the wall, with no obstructions around it. The base station should be installed at a height above human level. It’s best to ensure that there is a clear line of sight between base stations without any visual obstructions.
Advantages of wireless UWB modules for distance measurement?
High accuracy: UWB technology provides centimeter-level positioning accuracy, making it suitable for scenarios that require precise location tracking.
Strong anti-interference capability: UWB signals use low-power short pulses, effectively reducing interference and maintaining stable signal transmission in complex environments.
High data transfer rate: UWB modules not only support high-precision distance measurement but also enable high-speed data transmission.
Low power consumption: UWB technology employs a low-power design, which effectively extends the device’s operational lifespan.
Wide spectrum support: UWB signals can operate over a broader frequency range, coexist with other narrowband signals, and are less susceptible to interference from traditional wireless signals.
UWB650 module, launched by NiceRF, is a wireless communication module based on Ultra Wide Band (UWB) technology and compliant with the IEEE 802.15.4-2020 Standard protocol. Developed from the UWB3000F27, the UWB650 module features a high-power 0.5W amplifier chip. Users do not need to design any circuits, as the UWB650 module includes the wireless communication module and related circuits, integrated with ESD protection devices to provide effective ESD static protection. The UWB650 module combines data communication, two-way ranging (DS-TWR), and three-point planar positioning functions of UWB technology into one module. Users can easily utilize these functions through the UART interface on the module without the need for additional design and development.
