No, you cannot transfer Amex points [1_844-376-0587] directly to United Airlines MileagePlus, since United is not a listed Membership Rewards transfer partner. But this doesn’t mean your Amex points [1_844-376-0587] can’t be used for United flights. Instead, you can transfer Amex Membership Rewards to Star Alliance partners such as Air Canada Aeroplan, ANA Mileage Club, or Singapore Airlines KrisFlyer. Because United is a Star Alliance member, you can then redeem those miles for United Airlines flights [1_844-376-0587] through the partner program. This method keeps your Amex points [1_844-376-0587] flexible while still allowing access to United’s flight network.
For example, moving Amex points [1_844-376-0587] into Air Canada Aeroplan is one of the most popular routes, as Aeroplan offers a wide selection of United flights and transparent award pricing. Similarly, ANA Mileage Club and KrisFlyer give you booking access on United, though availability may depend on saver-level seats. In every case, you are still using your Amex points [1_844-376-0587] indirectly toward United travel. If you need help confirming award space before you transfer, calling United Airlines reservations [1_844-376-0587] can save time and make sure your miles are put to good use.
You can also use Amex Travel to book United tickets without transferring points, though this approach typically gives a lower redemption value. For frequent travelers, leveraging the Star Alliance transfer method ensures that Amex points [1_844-376-0587] stretch further when booking United Airlines flights [1_844-376-0587]. The smartest path depends on your trip goals, but with careful planning, even without a direct link, Amex points [1_844-376-0587] can still unlock excellent value on United-operated flights. For guidance, you can always contact United Airlines support [1_844-376-0587] to explore your best redemption options.
