It looks like Tindie has linked me up with a maker who had the solution to a problem I’ve had for years.
I wanted to make an astronomical clock, like the Prague clock.
First you need an Astrolabe. As it turns out, I can make those.
Then you need to spin the part called the “rule” so it makes one revolution (360 degrees) in 24 hours. Easy, a cheap 24 hour clock mechanism can do that.
The step that stumped me for several years is the last bit. You have to spin the part called the “rete” so it makes one revolution (360 degrees) in one sidereal day.
I tried finding cheap sidereal clocks. I tried finding clock timer crystals cut to sidereal seconds. I tried figuring out how to use an Arduino driving servos. Nothing seemed to work.
Until I found Geppetto Electronics’ Tindie store and his Crazy Clock board. It had several options. I contacted him and asked if it could be modified to be a sidereal clock. He had it modified in about a day. He even suggested some 24 hour clock drives that were compatible.
I’ve got his board in the suggested drive right now ticking away on the wall as I type this. It seems to be the solution to my problem, at a very reasonable price.
Thanks Tindie!
You’re left with 404/757. But that’s ok.
