+1—801—878—6858 Need Help with Canon Printer Offline Status? Start Here
Is your Canon printer showing offline +1—801—878—6858 when you try to print? This is a common issue for both Windows and Mac users. The good news is that it’s usually fixable in a few simple steps. Whether your Canon printer is connected via Wi-Fi or USB, this guide will help you bring it back online.
Why Is My Canon Printer Offline?
When your Canon printer displays Offline +1—801—878—6858” status, it means your computer is unable to communicate with the printer. This can be caused by:
  • Network connectivity issues
  • Incorrect printer settings
  • Outdated or corrupted drivers
  • The printer being turned off or in sleep mode
  • Changes to your Wi-Fi or router
Identifying the root cause is essential to resolving the issue quickly.
How to Fix Canon Printer Offline Error: Step-by-Step
Follow these steps to bring your Canon printer back online:
:white_check_mark: 1. Check Power and Connection
  • Make sure the printer is powered on.
  • Confirm that it’s connected to the same Wi-Fi network as your computer.
  • If using USB, ensure the cable is securely connected.
:electric_plug: Pro Tip: Restart your Canon printer and your router to refresh the connection.
:desktop_computer: 2. Set Canon as Default Printer (Windows)
On Windows, your printer might not be set as the default device:
  1. Go to Settings > Devices > Printers & Scanners
  2. Click on your Canon printer, then select Manage
  3. Click Set as default
Make sure the correct Canon model is selected.
:outbox_tray: 3. Remove “Use Printer Offline” Mode (Windows)
Sometimes this option is accidentally enabled:
  1. Open Control Panel > Devices and Printers
  2. Right-click your Canon printer and choose See what’s printing
  3. Click Printer in the top menu
  4. Uncheck Use Printer Offline
Your Canon printer should now switch to “Online” status.
:green_apple: 4. Reset Printing System (Mac)
For Mac users:
  1. Go to System Preferences > Printers & Scanners
  2. Right-click (or Control + click) in the printer list
  3. Select Reset printing system
  4. Re-add your Canon printer
This clears out old connections and reinstalls the printer cleanly.
:globe_with_meridians: 5. Reconnect Your Canon Printer to Wi-Fi
If you recently changed routers or passwords, your printer may no longer be connected to the network.
For Canon PIXMA and similar models:
  • Use the Wi-Fi setup wizard from the printer’s display panel
  • Select your SSID and enter the Wi-Fi password
  • Wait for confirmation that the connection is successful
If needed, for model-specific wireless setup instructions.
:arrows_counterclockwise: 6. Update or Reinstall Canon Printer Drivers
Outdated or corrupted drivers often cause connectivity issues.
  • Visit the official Canon support page
  • Enter your printer model
  • Download and install the latest drivers for your operating system
After installation, restart your computer and try printing again.
Extra Tips to Avoid Future Canon Printer Offline Errors
  • Keep your printer firmware and drivers up to date
  • Disable sleep mode if your printer goes offline frequently
  • Ensure your firewall or antivirus isn’t blocking the printer
  • Always connect to a 2.4GHz network (many Canon printers don’t support 5GHz)
:telephone_receiver: When to Contact Canon Support
If your Canon printer is still offline after trying all steps:
  • Contact Canon Customer Support +1-801-878-6858
  • Use live chat, email, or phone support
  • Have your printer model number and serial number ready
:white_check_mark: Final Thoughts
Seeing your Canon printer offline doesn’t mean it’s broken—it usually means there’s a simple communication issue between the printer and your computer or network. With the step-by-step solutions above, you should be able to fix the problem quickly and get back to printing.
