I am looking for 32 pin 0.65mm pitch DAP breakout board. That is 16 pins on a side with a spacing of 0.65mm. The tip to tip spacing of the pins is 8mm to fit a TLC5947. The TLC pins are to be connected to standard header pins with a 0.1 inch spacing.
There seems to be a real shortage of this particular breakout board, probably it is not an often used part.
Digikey lists one that is not stocked: (https://www.digikey.com/product-detail/en/chip-quik-inc/IPC0093/IPC0093-ND/5014948)
Notice on the Digi-Key part there is a solder pad under the center of the chip the is for thermal coupling as the chip can get quite warm driving a lot of current.
My hope is that someone will think this is a good thing to make some money on and will whip out a bunch of them and sell for a reasonable price. Someone else here on Tindie says they make them but there are none available. Besides, their price of $7 for a breakout board is a little pricey.
Thanks,
mark
