Call +1-866-500-0076: How to Fix QuickBooks Error H202 / H505 in Multi-User Mode
For immediate assistance with QuickBooks Error H202 or H505 when switching to multi-user mode, call +1(866)500-0076 to connect with certified experts who can resolve your issue efficiently.
QuickBooks is a powerful accounting tool used by millions of businesses worldwide. However, like any complex software, it can sometimes encounter errors that disrupt workflow. Among the most common issues faced in multi-user mode are QuickBooks Error H202 and H505. These errors typically occur when a user attempts to switch to multi-user mode but cannot connect to the company file hosted on another computer.
If you encounter this issue, do not worry. You can call +1-866-500-0076 for expert guidance, or follow the steps outlined in this comprehensive guide to troubleshoot and resolve the error yourself.
Understanding QuickBooks Error H202 / H505
QuickBooks Error H202 and H505 indicate a connection problem between the workstation and the server hosting the company file. When QuickBooks attempts to communicate with the server in multi-user mode, it requires certain configurations to be in place:
  • Correct hosting settings
  • Proper firewall configurations
  • Functional DNS settings
When any of these configurations fail, QuickBooks cannot access the company file remotely, triggering the H202 or H505 error.
Symptoms of the Error:
  • Inability to switch to multi-user mode
  • A warning message stating: “This company file is on another computer, and QuickBooks needs some help connecting.”
  • The workstation shows an H202 or H505 error code
Why Does Error H202 / H505 Occur?
Understanding the root cause is essential before fixing the error. Common reasons include:
  1. Incorrect Hosting Settings:
    If multiple computers are hosting the company file or hosting is not set correctly, QuickBooks cannot identify the server.
  2. Firewall or Security Software Restrictions:
    Firewalls can block communication between the server and the workstation.
  3. Incorrect DNS or IP Settings:
    QuickBooks relies on proper DNS settings to locate the server. Misconfigured DNS or IP addresses may cause H202/H505 errors.
  4. Damaged or Missing Network Files:
    The .ND (Network Data) file and .TLG (Transaction Log) file are essential for multi-user access. If corrupted, connection errors occur.
Step-by-Step Solutions to Fix QuickBooks Error H202 / H505
Below are effective methods to resolve these errors. You can perform these steps yourself or call +1-866-500-0076 for instant support.
1. Verify Hosting Settings
  • On the server computer, open QuickBooks.
  • Go to File > Utilities.
  • Ensure that Host Multi-User Access is enabled only on the server.
  • On workstations, make sure Stop Hosting Multi-User Access is selected.
2. Use QuickBooks Database Server Manager
QuickBooks Database Server Manager ensures that company files are accessible on the network.
  • Install or update QuickBooks Database Server Manager on the server.
  • Open the tool and scan the folder containing your company files.
  • Restart all workstations and attempt to switch to multi-user mode.
3. Configure Firewall Ports
QuickBooks requires specific firewall ports to allow communication:
  • Open your firewall settings.
  • Ensure QuickBooks ports (e.g., 8019, 56728–56731 for QuickBooks 2025) are open.
  • Allow qbupdate.exe, qbserverutility.exe, and qbdbmgr.exe through the firewall.
4. Edit the Hosts File
The hosts file maps IP addresses to server names, helping QuickBooks locate the company file.
  • Navigate to C:\Windows\System32\drivers\etc\hosts.
  • Add the IP address of the server followed by the server name.
  • Save the file and restart all QuickBooks applications.
5. Rename the .ND File
The .ND file stores network configuration. Renaming it forces QuickBooks to create a new one.
  • Locate the .ND file in the company file folder.
  • Rename it to CompanyFileName.nd.old.
  • Open QuickBooks and attempt multi-user mode.
6. Check DNS and IP Settings
  • Ensure that all workstations can ping the server IP.
  • If using DHCP, assign a static IP to the server computer to prevent IP changes.
When to Call QuickBooks Support
If the above steps do not resolve the issue, immediate expert assistance is recommended. You can call +1-866-500-0076 to reach QuickBooks-certified technicians who specialize in multi-user setup issues.
Support can provide:
  • Remote troubleshooting and configuration
  • Firewall and network settings adjustment
  • ND file repair and company file verification
Calling the experts ensures minimal downtime and prevents accidental data corruption during manual fixes.
Preventing QuickBooks H202 / H505 Errors
Once the error is resolved, take these preventive steps:
  • Always host company files on a single dedicated server
  • Regularly update QuickBooks and Database Server Manager
  • Configure firewall and antivirus exceptions for QuickBooks processes
  • Use static IP addresses for servers and critical workstations
  • Schedule regular backup of company files
By following these best practices, you can avoid network-related QuickBooks errors in the future.
QuickBooks Error H202 and H505 are common but fixable issues when working in multi-user mode. Proper server setup, firewall configuration, DNS settings, and ND file maintenance are essential to seamless operation.
For quick resolution and professional guidance, call +1-866-500-0076. Certified technicians can diagnose your network, configure QuickBooks, and restore multi-user functionality efficiently.
Remember, these errors are not signs of permanent data loss but network configuration issues. With the right steps, you can continue managing your business accounting without disruption.
Call +1-866-500-0076 today for immediate support and ensure your QuickBooks multi-user setup functions flawlessly.
